88SPL swapping lower unit: shift linkage question
MAW31
the lower unit on my 1994 SPL88 had a broken skeg at the bottom of it, and because of that, when i ran aground, i lost some gear teeth...as evidenced by chunks attached to the lower magnet. It still runs ok and makes no noise but I cannot enjoy myself on the water knowing its potential cannon balling.
i found an older, but much better shape lower unit casing and was going to simply swap in.
As you can see from the picture, the top of the shift linkage is slightly different.
'A' is my original, a 1994 88SPL
'B' is the replacement: am told was off an 1986 88SPL
Is it a large task to change the shift linkage?
It appears that the offset is close, but not quite.
As an alternative, i'm thinking..."I have acetylene"..i'll shape it...
With both lower units in neutral, the measured height distance is near identical (1/8" diff)
What am i getting into to swap the linkage.
thanks all
MAW31
Re: 88SPL swapping lower unit: shift linkage question
ok.
I just took the cover off the shift linkage and it simply unscrews...
and...in my own defense ^^...the schematic breakout in the manual didnt help. The linkage just dead ended. I studied it and never thought it just scews in...
anywho problem solved.
