Recently purchased 100 hp Sea ray. Had trouble starting after sitting on the lake a bit. A gentleman assisted us and said 'Did you try 'fast idle'? He moved throttle lever fwd. and turned key and it popped right off. How did he do this? When I hooked up to muffs at home to start when ever i try moving throttle fwd. key will not engage starter. Manual says push 'Throttle Only' button in while advancing lever forward. My throttle lever does not have that 'Throttle Only' Button, Just the lever, trim up/down button and button underneath handle for shifting. Thanks in advance!
