89 125 cranks but no start, no park
The boat was running great when I parked it and winterized it. She's been covered for 4 years. I cleaned everyrhing up, carbs,tank,new battery etc. I tried starting last night. No go. I pulled plug wire and checked for spark, none found, I removed the two white wires, no diff. I suspect the stator but why would it go bad. For $463.00 I don't want to just buy one. Any suggestions on checking with Fluke multi meter? It would be hard to belive all 4 coil packs are bad?please help with any suggestions before I take to a repair shop.
john from md
Re: 89 125 cranks but no start, no park
If you know how to use a Fluke meter, all you need to buy is a Clymer Force Outboard Shop Manual. It will allow you to ohm out all of the components before spending money you didn't need to spend.
I would clean all of the engine grounds, coil grounds and connectors on the CDI's. All it takes is a little corrosion to stop you from getting spark.
John
Found my problem, took the flywheel off and found that the magnet thats glued to the flywheel was not spinning with the flywheel., glued it back on with epoxy and she fired right up. purrs like a kitten. while taking the fylwheel i broke the timing connecting rod end, (black plastic) anyone know wher I can get one of these, im going to try to jb weld it back together. Ill call a delaer on Monday.
Thanks,
Chris
