put water strap on engine started it, the vote meter on the boat was not working, check with volt meter on the stator and was getting the A/C voltage but none on the rectifier from the red wire to ground on D/C. here's the good part turned the engine off and started back up and the volt meter on the boat was working and check the voltage coming off the recifier and was getting 13 plus volts idling the small purple red and gray wire that comes from the rectifier goes into the wiring harness upto key switch area does any of these wire have to feed back through to make the rectifier work. could the key switch be going bad . Thanks David
