I have found that the piston top right (standing behind) has locked up motor.Removed piston and found the pin that holds the ring in place on piston slid out and scratched the cylinder wall.<br />I was going to change water pump after i noticed 40 % water flow out of pee hole i guess i should have done it before i went out.Question-why did pin slide out? Does low water flow to head cause these types of seizures? mercury dealer said no over sized pistons made.Weisco said they had 10,20,30 over but all need to be on a re-sleeved cylinder.I would like to bore 10 over if it will cover scratch. Some one must make a piston for it in 10 over with no re sleeve required.
