Hey guys I am really new to boats, i have a 1989 1950 bayliner capri with a ford 302 v8 in it.
Took it out yesterday and have the following problems looking for help on them
1. There is an "oil cooler" on the back right side of the engine, this connects to a pump on the front right.... I had to remove this cooler because it had/has a pinhole leek in it. I tried to patch it but it didnt hold, however I lost some fluid out of it and re-filled it with stern drive oil--now I know im probably stupid for thinking that as I now think it is power steering oil. Any comments on this? How do I flush it? What should I put back in it?
2. When shifting from neutral to gear the engine will usually die unless I do it quickly.. this makes it tough to do anything near a dock. How do I fix that? Once warmed up the boat will idle real well, but until warm I have to keep it 1500+ rpms or else it will die.
Thanks everyone!
EDIT: from what i have read it seems this is a combo of shift cables and the ESA switch. The shift cable I believe is the "updated" newer one.
Thanks everyone!
