'89 4.3l won't restart in water
Jswingle13
Runs great on muffs and starts and runs after launching. Once I shut it off to go swimming, etc it won't restart? It turns over just won't fire. This is my first boat and I have read the service manuals. I have always been handy with vehicles but I am quickly learning there is a big differance. Any ideas would be greatly appreciated.
Bt Doctur
Re: '89 4.3l won't restart in water
Most times you need to pump the throttle and leave it slightly open .but you dont mention what 4.3. carb, injected, ,?????
ohioriverat
I have a 1992 model and i usually give it a slight bit of throttle when restarting on the water, she seems to flood a little and starts right up this way, it is a very simple engine nothing like the outboards.. do you lose spark? when does it restart and how do you get it out of the water?
ohioriverat
I love this forum you guys are the best at helping people..happy boating!!It's Saturday!!!!
Jswingle13
It seems to flood and I end up using a paddle to get back...after the first time it happened I learned to keep it close to the ramp. I didn't check to see if I lost spark at that point. It has a 2-barrel carb. After I get it home and hook the muffs up it will start.
WILSONS88
Sounds like its time to rebuild the carb if its flooding out. Sticking float, needle not seating properly. Try running some seafoam (fuel additive) through it. Sometimes it will help.
Jswingle13
I will look at rebuilding the carb anyhow, I also picked up a new cap and rotor and set of plugs. Other than winterizing and oil changes I don't think any major maintenance has been done on this boat.
Don S
Do you use the throttle only position of the throttle/shifter control to open the throttle when starting?
Jswingle13
Yes, when I first launch I pump it once and pull it back and it fires and runs good. When trying to restart I leave it in neutral in fear of flooding it, Once warm it should fire right up? after cranking and no fire I will pump it once or twice and try again with no luck.
Don S
Sounds to me like you are unfamiliar with carbed engines. They do not start like an EFI engine.
Move the lever to about 1/4 to 1/3 throttle and see if it starts. If you suspect it's flooded, you go to wide open throttle and crank the engine till it starts.
Jswingle13
Why would it start right away cold but not warm? The first time it happened I did try wot after it wouldn't restart. I have some more clues after thinking abOut it...after sitting in the water not running, I started getting water in my bilge. There is no water in my oil and I dont hydrolock. Upon further inspection I have found a tear in my shift bellows, the other bellows seem fine. Could this have anything to do with it?
cr2k
Because a cold engine needs more fuel to start, hence the invention of the choke.
Volphin
I agree with the other posters... carb rebuild would do it a world of good as would those new plugs & dist cap. Check the base timing too. It sounds slightly retarded. When properly adjusted, a 4.3L will fire right up with no throttle needed. You just touch the key on mine and she fires right up.
HTH
V
