hello i'm new here... not new to using forums tho. i have a 1989 johnson 40hp on a 16ft basstracker. bought the boat in dec of 08, it hadnt been ran for 3 years drained the carbs and got it running. since then i have only been able to use it once since my local lake has a 25hp limit! anyway it ran great on the water... this has been 3 weeks ago. now i try to start it and it will eitheir... 1. fire once or twice. 2. run for 5 seconds and die. 3. nothing! i replaced the spark plugs.. the old ones were colder than the book called for and now have the correct ones installed. so i am beging to question if the fuel pump is working?? i cannot hear it clicking or anything when i press down on the key switch. as where i did before. i used a test light and checked it today, it doesnt seem to be getting any power? is there a fuse somewhere? i'm not even sure if this is my problem....
