It started when I was actually planed out and the motor suddenly died. Now It starts and idles fine, but when I try to take off and plane out there is no power. I am thinking maybe a fuel filter or pump?
Howdy, Hattrx.<br /><br />Sounds like you dropped a cylinder. See what happens if you disable each cylinder.<br /><br />Got hot, blue spark to each? Try squirting a bit of fuel mix into each carb while running under load. If it picks right up you have a fuel supply problem. <br /><br />Fuel supply trouble will usually affect both cylinders. Carb trouble will affect just one cylinder.<br /><br />Good luck.
