The other day I was on the lake and something was rattling along with my belt squeeling. I believe this led to my problems. I had changed the altenator belt (the one in the back) a few weeks before and in the process took off the front belt (the power steering belt?). After reading some threads it seems like the belt was too tight and now I have a worn out bearing since it has locked up, and burned my belt. Since I believe I know my problem I need help identifying the part. The pulley on the top right hand corner (outside) is the one that appears to be warped/broken/locked up. Is this a tensioner/idler or is there a better name for this part I can find and order to replace. Do I replace the bearing or the entire pulley? Also, how much tension should there be in my belts?
Thanks for any help.
