Hi guys Sven here from Sweden.
I recently bought my first boat from a friend its a bayliner 2755 from 89 that has flooding problem.
The engine is 5.8l OMC with 4160 Holley marine carb. The carb was rebuild by a mechanic because of this problem but it still didn’t help.
When we adjust the air&fuel mixture screws as Holley advice the engine stalls about 5 to 10 seconds and sometimes a minute after start and won’t start for like 30 minutes again cause of too much fuel. And Engine backfires as well over 2500rpm.
If we close the air&fuel screws all the way in and open secondary ports to put more air in it the engine starts and runs just fine. No backfires nothing but won’t start without opening secondary ports manually.
So I am wondering how is this possible ? When the air&fuel screws are closed carb should not send fuel right ?
What can be the problem here ? Vacuum leak or bad rebuild carb that’s leaking to the intake manifold ?
Didn’t know a thing about engines till I bought this so have a little patience with me lol what should I look for here, would appreciate all help, thanks.
Attached a video.. engine runs like this when the air&fuel mixture screws are closed. ( Screwed all the way in )
