TheFormerlives
- Joined
- Feb 23, 2010
- 62
Its a 50hp Force. After sitting around for a week it'll start right up and idle nice and smooth, but if I let it idle for more than 2 or 3 minutes it'll cut out. Then it'll be hard to start back up and even harder to get into gear without cutting out. Once I get it started and in gear it drives fine, WOT is great no problems. But as soon as I bring it back down to idle speed (in gear and neutral) it'll cut out again. Bulb gets soft but not flat. Pump the bulb and she gets good and hard again but will still start rough.
I replaced all fuel lines, fuel pump diaphram, cleaned the carb bowl. Spark plugs are 1 year old and aren't fouled too bad. Fuel/oil mixture is correct, compression is 120 on both cylinders. Any suggestions guys????
