I have a '89 50 hp force with a locked up lower unit. When we broke it down we found the brass/bronze bushing below the water pump was frozen to the shaft. There is a groove on the outside of the bushing running long ways and a groove on the inside of the L/U housing. Is this for a roll pin or is this a groove for oil to be pumped up in. There is a hole in the groove on the housing which seems to go down into the gears. I thought maybe this was to allow oil to get up to the bushing and therefore the groove is not for a roll pin. Should the shaft spin freely inside the bushing as is. We are not sure why the bushing froze to the shaft and think it is from a lack of lubrication.
