Re: 89' 70 horse Johnson power surge
Welcome to iboats!<br /><br />Definitely sounds fuel related. Either your gas, or if your gas is fine, how your engine is getting it or the lack thereof. Check the simplest things first... Do you have internal or external gas tanks? If external, then make sure your vent is open. I've had them vibrate shut before, and the engine has trouble getting gas then. Is your fuel fresh? Look for a clog in your fuel line by pushing the ball on the connector end that goes to the engine. If your fuel bulb is pumped tight, then gas should squirt out fine. New fuel filter wouldn't hurt either. If all that doesn't help, then spray some carb cleaner in your carbs. There may be some plugging there. Keep us posted.<br /><br />Jeff
