89, 85HP Force LU Slop Question
TWFisher
Is it natural to have play or slop between the lower unit and the rest of the motor. If I hold my hand on the back of the motor, preventing the motor from moving, and grab the cavitation plate with the other hand, I can move the lower unit froward and aft about a 1/2 inch each way. Is this normal or should it be completely rigid?
See the attached photo, the portion of the lower unit below the red line moves independently of the rest of the motor.
bobby10482
Re: 89, 85HP Force LU Slop Question
Is The Hole Lower Unit Moving With The Mid Section Check All Your Bolt On Lower Unit See If They Are Tight I Have A 85 Force The Bolt Tend To Loosen From Fibration Try Red Loctight On Them
TWFisher
Nevermind, I looked in the manual for beter terminology to describe my situation and found out what's going on. It's doing what it's designed to do. The whole motor leg is allowed to move. The power head is mounted on bushings. I pulled the top and can see all moving together. I wasn't sure if something had worked loose but all is OK,
Thanks,
