I've been recommissioning this motor after it sat for 5 years. I've been through everything, some things twice.
I'm trying to deal with adjusting the idle now after cleaning the carbs but the overheat alarm keeps sounding intermitently.
First, i had found that my 1st new impeller had split. I had known that I didn't see water coming out of the exhausy holes. A new impeller and new gaskets, seal and I am getting a good spray now. It doesn't overheat right away. I haven'tyet been able to get it in gear. I'm just idling right now. Earlier today, I found out that cylinder 3 was not firing. Found the problem, a short where the CD wire was pinched by a screw of the fuel pump. Fixed that, started her up and and had the highest rpm's so far. Had to throttle back it was idling over 2000 rpm's. I cannot get the throttle back to center position or even close without it cutting out. I know I need to adjust the idle mix but my manual says to do that in forward gear. I am unable to throttle back to put it in gear. As I'm waiting for it to warm up and try to slowly work the throttle back, it will sound the overheat alarm. It is too hot to touch so it definitely is overheated. Are these issues related? Do I have the link and sync confused? I have the Seloc manual and a US Marine manual for 3 cylinder motors.
One thing. The Seloc manual and the US Marine manual both show the thermostat in the opposite position from a micro-fiche I got of the parts and build sheet for my particular model from US Marine. It is an H model, a late model that resembles the L drive and the 1990 model. It has the thermostat turned opposite from the manual's position and it has a spring to hold the thermostat in place. Originally, I thought it had been done that way by a previous owner's mechanic. Then I saw it was positioned that way with the spring in my build sheet for the H model that was provided by the manufacturer.
I am getting the Clymer manual since I read here it explains the link and sync better. I've become confused. But I think my confusion is because of my throttle problem.
I haven't ever done timing. To anything. Could this be my big problem. I can't see how I could do the timing as long as I have this overheating.
Overheating?
Throttle position at control.
Can't put boat in gear.
It starts easily,decarbed with seafoam also. Last time I checked, compression was 135, 135, 130.
thanks.
Overheating?
thanks.
