Re: 89 85hp Force ring gap clearance
You need not worry with the Wiseco piston. I have never had one that was too tight. However, the guy that does my boring is an ace--so the bore is right on spec. When you see the Wiseco rings, you should appreciate good engineering. Note the way they are pinned in the piston--very nice!
