89 bass tracker restoration
bbarrick
planning on recarpeting (and replacing front deck and floorboard) my 17 ft 1989 bass tracker. its my first boat fix of any kind. ive got a pretty good idea of all thats involved by researching and reading these forums, but can anyone tell me how much carpet i should expect to need. im in kuwait right now and want to get started as soon as i get back, so id like to go ahead and order everything i can so i can start work immediately.
scubby
Re: 89 bass tracker restoration
I have a 17' Tracker that I am in the middle of restoring. I measured my boat for carpet and came-up with around 13 yards I will need. The problem is I am sure our boats are not identical. I have changed the configuration (casting deck sq. footage, storage, etc.) of my boat to suit my needs. If you want an accurate measurement for your boat I would recommend waiting until you return home, then measuring it to ensure you order only what you need. Good luck.
bbarrick
yeah, ill be extending my deck as well, and attempting to add a rod box. just trying to guestimate. thanks for the info.
jigngrub
I used 30 lin. ft. of 6' (20 sq. yds.) wide on my Tracker Pro Deep V and very little left over and very little waste. If you measure everything out, you will need more than that. Remember that carpet has a directional grain and has got to be laid in the same direction to look right.
Teamster
I'd wait to order until you get a chance to measure it and figure it out,...
Most places get get it shipped out and to you in under a week,........
