alittledinghy
- Joined
- May 15, 2003
- 83
This motor overheated and wouldn't start or run well afterwords. the primary cause of the overheat was a clogged water intake. After inspection, the hard starting was caused by a bad choke solenoid.new water pump impeller and cooling lines are open. starts now and idles rough. Compression test is as follows with water in the middle and bottom cylinders. Top cyl. is 120 PSI., middle cyl.is 005 psi., bottom cyl.is 130 psi.. This sounds like a blown head gasket to me, what do you folks think. I won't have time to look at it till the weekend.
