Andy Hatch
- Joined
- Jan 29, 2009
- 13
My first boat and my first post on any thread/forum. Imagine That !!!
I was out running the boat at full throttle, like normal when going fishing, and it jumped in and out of gear twice and the rpm's climbed a lot. I pulled the remote to neutral and shut it down. Trimmed the motor up and checked my newer prop for visible damage. None there. Started the motor back up just fine and put in reverse. Works perfect in reverse at any rpm's. Put it in forward and works great until I give it any throttle. She jumps in and out of gear and vibrates a lot. I put it in forward with no throttle and limped back to the dock. Got home and checked out the linkages. All's well. Disconnected the shift cable and it works smooth. I also, adjusted the cable forward until I lost my reverse shift and backed it down 4 turns. Nothing changed. No problems at home. All is well until I water test at the dock and get the prop under a load. Same problem occurs.
Anyone have a service manual download of this motor?
Any suggestions? Thanks....
