skibrain
- Joined
- Jun 17, 2004
- 766
I've owned this boat and motor for about 7 yrs. Runs great.
The motor makes a sharp beep when ignition is turned to on - then the horn dies (quits making noise). Occasionally since I've had the boat, this beep has kept going. It is more typical if the boat has been sitting, like in the spring after being in storage.
Always, by turning the key on/off 6-10 times it has remedied itself. But today after the boat sat for a month, the horn would not go off. Yes there is oil in the tank. the VRO pump works. The boat was not overheated. It was cold.
the horn would not go off. I have half a mind to disable this thing, but I'd love to hear from someone with insight as to what could be causing this. I suspect some type of corrosion or a bad contact or loose wire...and likely right at the control.
Anyone have an idea?
Thanks.
Thanks.
