bamabassbuster
- Joined
- Apr 5, 2005
- 17
Hi,<br /> I have an 89 Evinrude 150 Xp on a 17 1/2' blazer bass rig. The boat runs great and seems to get on plane fast and has great top end. But, i have a problem with it wanting to bog down and quit running when I am trailering it. Motor is trimmed up some. Also, the idle seems a bit on the low side, idles till put in gear then dies. maybe 600 to 700 rpms when in gear at idle speed. I have picked up an repair guide to help make adjustments to the idle speed. I was thinking that rebuilding the carbs would solve bogging issue and maybe get me a better idle speed after reading some of the other post with simular problems. <br /><br />Since i have discovered this site a few weeks ago, I have done the following to the engine.<br />Decarbed well, with seafoam deepcreep. what a difference that made, it runs alot smoother now! Also i have changed the spark plugs, the ones that came out were oily and kinda wet looking but not badly. <br /><br />will a carb rebuild/cleaning solve this?
