89 evinrude 150 V6
fasttalker31
i just bought a older champion boat, and it has a 33 gallon tank, and i just noticed today that there is one fuel line running into the motor and the other gas line connection on the motor is capped of and it is dripping fuel. should i completly seal that one off or what do i need to do? I notice when i pump the bulb it has alot of air
thanks
Ken:confused:
tashasdaddy
Re: 89 evinrude 150 V6
the other line is the oil line. the vro has be disabled on the motor, you need to mix your fuel 50:1, the leak is fuel coming back from the fuel pump. seal it off. the bulb will not get hard because of the leak. also if it is an aftermarket bulb, there is an arrow on the bulb, that should point toward the motor, also when pumping, point the arrow to the ski, they work better in that postion.
