Cat nip
- Joined
- Jul 25, 2015
- 288
Yesterday on the river I got to the first fishing spot and when I put it in neutral to set the anchor the idle was at 300 rpm. Seemed to be ok in gear and was running fine but never got past half throttle because it was a new streach of river for me and the water was high and fast with lumber . Did this all day and never had a problem before. Started it in a tank today and its still at 3000 rpm. Throttle plates all fully closed, no vacuum leaks that I can find, pumping fuel bulb dosent seem to make a difference. If I smother the upper carbs one at a time with my hand it slows way down and will die but when I cover the bottom carb there is no change. I took the carb off and cleaned it with no change. It is getting fuel to all 3 carbs. I cant get my compression tester till tomorrow. Any ideas?
