Jmitch1102
- Joined
- Nov 26, 2017
- 74
i have a 89 Evinrude 140 that is stuck in forward gear no matter the shifter position including throttle only. I just replsced the water pump. This is the first time out since the new pump. I had the lower in reverse when I took it out and left it in reverse when I realized installed it. The lower gave me trouble putting it back on and the shifter did spin around a few times. Can I just disconnect the linkage and then using needle nose spin in back tight then reconnect it? Any help is appreciated. Thanks
