Re: 89 Force 125 Shifter Linkage question
I'll assume that your '89 engine has the same controls as my '88. Which is one black cable for throttle and one red cable for shifting connected to what I think is a teleflex control.<br /><br />first thing is to pull back the collars so that the cables are not connected. with cowling off, push and pull the control handle. make sure that the cables move properly. the red cable goes either in or out depending on reverse/forward. the black cable goes in the same direction either way.<br /><br />next, raise and lower the shift linkage while spinng the prop by hand. find the mid-point of neutral and make sure that your neutral saftey switch is centered at this point. with the control handle in neutral adjust your shift cable length so that the switch is properly centered.<br /><br />for the throttle. this is a good time to check your linkage adjustments per the manual. It is also the ideal time to set your idle speed if you have a problem conking out when shifting into gear. mercury mechanics like to set idle in their shops while boat is in neutral which often leads to conk-outs. ideal is to set your engine to idle at 700rpm while in gear. Once you are satisfied with your idle speed then adjust the throttle cable length to match location of ball joint and re-attach. then push the throttle all the way forward and look at butterfly valve. the shaft is squarish shaped on the end and aligns with the the actual butterfly inside carberator. At full throttle, the flat sides should be horizontal and/or pointed directly into engine. If it is not, the short rod in roscoe's picture #2 is used to make the adjustment.<br /><br />my guess is that you might have mixed up the throttle and shifter cables. but there is still no better time to check your linkages than now. even 1/8 of an inch can make your engine lose 1000rpm off the top end.
