MustangJAB02
- Joined
- Aug 25, 2009
- 9
I just rebuilt my 89 Force 150. I had to rebuild the starter also. Now it is turning over and has spark. It seams that the problem is with the fuel. We can't seem to get it started. There is a quick connect on the fuel line by the squeeze pump and it is not air tight. it sucks in air when you let go and squirts a little fuel when you squeeze. Bad O ring? we are able to fill the carbs after pumping by hand for quite awhile. Cleaned out carbs and made sure floats worked properly. Any ideas? Please help, thank you!
