timmeraw
- Joined
- Jun 10, 2008
- 258
Hi,
Just picked up a pair of ?89 Force motors. One 50 and one 35hp. The 50 is running great but for a pretty loud knock/tap. In any case I sold it cheap to a kid who was aware and willing to figure it out.
Now for the 35. Fired it up and it ran but would only stay running on an advanced idle. Checked compression and sure enough the lower cyl was low?real low. Like 40-50psi. Thinking maybe stuck ring or something?warmed up?doused the cyl with seafoam and marvs mystery oil and let set for a bit. Compression increased some to 70 psi so I know something is wrong. Pulled the head and found this:
It is a gouge that something has worn into the cyl wall. Do you think it could be bored out and then use an oversized piston?
Any suggestions would be greatly appreciated.
Thanks,
Tim
Thanks,
Tim
