Eddie Rivera
- Joined
- Feb 19, 2013
- 183
Hello guys, I'm back I had to take a brake from working on my boat - I got burnt out. I've started working on it now and need help.
89 force 50 hp I need to replace exhaust Gaskets. Ontario - Southern California (inland empire) Please help me with instructions on how to do it. Any special tricks anything to watch out for anything I should not do.
You guys told me to remove the bottom end to make it easier. Anything to watch out for when I do that?
I will replace some seals and gaskets on the carb also. Will I mess up my timing in anyway when I do this?
I'm thinking of only removing what I must to lessen the work - example - leaving the stator on with wires attached to the plate and hold plate to motor.
Help!!
Help!!
