Re: 89 force vapor lock???????????
It's time for a compression test.<br />These engines often start leaking at the exaust port plate gaskets.<br />Primary cause of failure of this gasket is running an improper, or no thermostat,changing the temps inside the exaust port,while running in ice cold water--thus warping the plates,causing the gaskets to fail,yadayada. Not much you can do about it, but buy a gasket set for the plates and head, and replace them.<br />Not sayin this is your motor's failure, but a higher than average possabiltiy, and the first place I would look.<br /><br />While the plugs are out for the compression test, look for a very clean plug or plugs. This would indicate water injestion,which is steam-cleaning them, and the head gasket should be replaced,and compression re-checked.<br /><br />Still vapor lock, just a different vapor.
