I have a 1989 four Winns candia with a Chevy 5.7 and omc outdrive,just rebuilt the motor over the winter,runs great when giving it gas,goes about 42 towards the top end,problem is after the motor heats up to about 150 and I come off of plane to an idle the motor chugs then stalls,then it’s hard to restart,I have put new plugs,wires,coil and when I swapped blocks I ended up using a marine electric fuel pump in,also have new shutters installed along with a new impeller.if anyone has an idea what to look at next I would really appreciate it,starting to think the carb needs to be rebuilt but not sure.thank you!!!
