got an 89 cobia with v8 gm 305cid 225hp 5.0 with alpha 1.....the boat will run at 200 degrees all day long no matter how fast or slow, i thought it was the impeller, complete rebuilt it, still the same temp, maybe 4 degrees cooler if that, new water pump, sender,thermostat housing, any other things to check? risers? manifolds? oh yea, when on the muffs the water coming out of the tell tale, one side has more water coming out than the other side, could that side be clogged or something? do they make draino for boats as i run in salt water?
