1989 J50 J50TLCEC<br /><br />I just replaced the lower unit with a rebuilt one. It ran fine in the driveway on muffs after installation (probably around 15 min). Took a little cruise on Sunday and mostly putted around. The motor tell tail was nice & strong the whole trip. When we got back to the ramp the motor would not idle. The spark level had slit where the idle stop screw is and I couldnt adjust the idle. I am ordering a new lever today. Will do a link & sync after installation.<br /><br />Anyway, when I was flushing the motor after the trip, the tell tail wasnt very strong (had the hose on full) and the overheat alarm went off. I shut the motor off immediately. I noticed that the tell tail water was very warm and the exhaust water felt ok. Any ideas on what to check? I will check the impeller to see if it was installed correctly and that the key is not sheared. I will also be replacing the t-stat. Do you think the head gasket is ok? It sounds like there may be an obstruction in the water passages if the impeller is ok.<br /><br />Thanks again.
