Re: '89 J60 TLCE Loads up under load, won't run out past 2000 rpm
Good evening,
Not too sure about this model with VRO, but, following schematic it looks like the oiler pump also functions as a fuel pump. Any chance the fuel pump portion has also been disabled? How'd it run before the VRO disable?
Someone else with knowledge can jump in.
Also, before you tear into the carburetor, check fuel lines for air leaks, especially around the connections.
Will the engine run more consistently or increase RPM if you squeeze the fuel ball primer?
J
