Re: 89 johnson 110 hp need help
Built in or portable fuel tank? If built in, check for air leaks in fuel plumbing, stuck anti-siphon valve, crap covering pickup screen, cracked pickup tube, plugged vent, etc. Try with a different tank to see if results are different.
Have you tried activating the choke/primer when it starts to die and noted the result? Or squeezed the primer ball? Either will confirm a fuel supply problem.
You can also check the fuel pump output once you confirm a fuel supply issue.
BTW, the only way to clean carbs is complete dis assembly, soak overnight and blow dry and clean all passages.
