89 Johnson 110 idle
torijake
Think i finally got most of the kinks worked out of motor and is running pretty well,just the idle seems high but not sure what rpm it should be at cold and hot.Thanks John
tashasdaddy
Re: 89 Johnson 110 idle
your idle should be IN THE WATER, AND IN GEAR 600-750, it will be higher on muffs, and in neutral.
torijake
Thanx for your quick reply.Thats what i was hoping to hear (from amatuer).Is idleing at about 850-900 with muffs,going to drop it in the water tomorrow and hope the good roll continues and all is well on the water this time!!!!!
Thanx again..........John..............
