Looking for some help with my Johnny.
Background: Rebuilt the carbs and removed VRO pump system. Installed two port fuel pump. New fuel lines and fuel bulb.
Fuel Bulb pumps firm and I can prime the motor at the throttle and the motor will turn over and will idle for a short time then die.
It will start and idle every time I prime the motor at the key but will die shortly after. I installed a clear fuel filter and you can see fuel in the filter. The level of fuel in the filter will often slowly trickle down as if it is being pulled back toward the tank.
I have the vent open on the fuel tank, and the fuel bulb is pointing in the right direction.
Please help me figure this problem out.
Caddis295
Caddis295
