Re: 89 johnson 9.9 water problem / Lower unit removal
Thanks, that definitely makes a lot of sense, its my first outboard and I've used it twice so I'm trying to learn about it. So the fuel comes in on the right and through the crank and up into the cylinders from the left side? And I believe the exhaust also exits through the same holes but the reeds are closed on the exhaust stroke so I guess that it would be normal for the port side to be too hot to touch? I probably didn't have the intakes deep enough in the water in my barrell which explains why there was no water from the tell tale. If this is the case there might not actually be anything wrong
