What pitch is best depends on your intended use. For example, a higher pitch "speed" prop is not very good for water sports.
Higher pitch yields more top speed at the expense of acceleration(pulling power).
I believe your WOT rpm range is 4200-4600.
A test run is required to see where you fall in your rpm range.
