Hey Guys- haven't even laid eyes on this motor yet so can't give you a serial number but I'm hoping for a starting point.
it's an 89 Mariner 4 cylinder 2 stroke with oil injection- the owner tells me it has flat plugs(no ground strap to adjust gap) which i wasn't even aware was a thing until he told me and i checked, but that doesn't seem to be the problem anyways. The engine ran great for the 1st summer, then seemed to develop this issue- that being that while under load in the water- it won't go over 2000rpm. He can squeeze the primer bulb and it will pick up a bit(his words not mine, again, I won't see it until tomorrow.) that to me says he most likely needs a fuel pump- would anyone agree with that? more info- new tank, fuel line with primer bulb, fittings on tank and engine, filter.
Another thing that may be an issue- high speed jets on the carbs? I don't know enough to say for sure if this is actually a possibility since I haven't looked at the carb parts diagram- would need the serial to find the right parts list i'm guessing.
Really appreciate any help you guys can offer as to where to start with this- it's an hr drive from me and probably 30mins from anywhere you can buy anything so I'd like to get it in 2 trips if possible, lol, that's very optimistic i know.
Thanks,
Matt
Thanks,
Matt
