'89 Merc 100HP 4-cyl - - Too low rpm's harmful ?
MartyTn
This is a question I've wondered about, so I'd like to ask it here - it's about outboards. I changed from a power prop to a cruise prop on my 17' SeaRay with '89 Merc 100HP outboard. I love the new prop's performance, it's got good hole shot power and good cruising speed. To get full recommended WOT however, it needs to be trimmed exactly right. Now, when I'm just cruising - usually around 3500rpm or so, I get it trimmed okay, but maybe not exactly the greatest that it could be. The motor feels great, but could I possibly be lugging it and hurting it at this lower speed if it's not trimmed exactly the best that it could be ??<br />Many Thanks, Marty...
JB
Re: '89 Merc 100HP 4-cyl - - Too low rpm's harmful ?
Hi, Marty.<br /><br />Sounds like you are okay. If you don't have the throttle wide open there is no problem with running at below top rpm.<br /><br />It would be harmful if, at wide open throttle, you weren't able to trim it for top rpm. <br /><br />Good luck. :)
MartyTn
Thanks JB. I sure was hoping that was the case. :)
