farlee308024
- Joined
- Jul 6, 2009
- 3
Hi everybody I am new to the site. I have some problems with my 1989 Mercury 115. I took it out for my first time (just bought the boat). It started right up left it running while wife took the truck/trailer to a parking spot it was about 5/10 min?s when she got back. We took off from the boat launch and for about 45 min?s the boat ran fine. Then I got what I believe is the overheat alarm on my remote because the oil injection system is still active and the oil tank was still full. There was little to moderate stream coming from the engine. When I got home from the lake I hooked up the muffs to the engine and now no water I had the hose on full blast and to make sure there was no issue with the hose/muffs I lower the motor in my dunk tank and tried it again for about 30 seconds and no go.
So here are my questions
-I guessing, I?m going to have to rebuild my water pump Correct?
- What else should I replace when I do this?
- How would I check psi on the motor?
- When I checked the oil tank there was a large sucking sound when I released the cap. Should I invest into a new oil cap?
- What are your opinions on the oil injection systems on mercury?s?
-I know this might sound stupid I just want to make sure it?s the overheat alarm and not the low oil alarm. It?s just a constant beeping, I have only own Evinrude motors before and they had horns.
-I also forgot the alarm will not shut off and it has been two days
