89 merc wiring harness diagram
thejeep007
Finally got new engine in but one of the pin connectors pulled out on removal. Does anyone know which wire the gray one on the boat side of harness connect to thanks guys
stonyloam
Re: 89 merc wiring harness diagram
I believe it should go from the coil - to the tachometer. Pin #2?
thejeep007
Would that explain why my positive wire from electronic ignition is smoking every time I crank?
thejeep007
Smoking wire was pinching wire under cap. So can I bypass the harness to the gray coil wire?
Ayuh,... Ya won't have a Tach, til ya do, or repair the connection somehow,...
Just by-pass the cannon plug for the tach,...
thejeep007
Yup you guys nailed it thanks now my next post... Ugh
