Cjpainten
- Joined
- Sep 11, 2017
- 72
Everything was working properly except for the up solenoid which would click from time to time. Replaced both solenoids, took apart electric motor and cleaned it up, put everything back together and somehow overtightened the motor to the pump, crushing coupler in the process. Ordered a new coupler and took apart hydraulic pump to make sure everything was ok internally. Cleaned up hydraulic pump and put back together. Topped up system with 10w30 and put everything back together. Trim goes up perfectly, but when I attempt to lower it the electric motor runs but the unit does not lower. If I open up the relief valve on the pump the drive will slowly lower. The pump builds pressure to go up but not down. Does anyone have an idea where to look? When I had the internal pump apart I tested it and it worked in both directions.
