General Lee I
- Joined
- Jul 19, 2011
- 25
I currently use 89 octane in my 1991 4.3 OMC Cobra, is there an advantage of using 89 octane vs 87 octane, does anyone know what is recommended for this engine?
Thanks
Thanks
My marina only sells premium non ethanol, so that's what goes in the boat- boat runs just fine on regular. Runs just fine on 10% ethanol, but it's a real PITA to fill up a 25 gallon take hauling in cans.
Essentially true. Octane number is a dimensionless number that indicates a gasoline's knock resistance. Higher "Octane" = more resistance to "ping" Wikipedia has a great description.... but they're sometimes not accurate. API backs up what they say... http://www.api.org/aboutoilgas/gasoline/gasoline-octane.cfmimho, i think octane is a detonation inhibitor.
Your brother is absolutely right. If you're using 93 octane in ANY engine that requires 87 octane, you're wasting money.i told him i was using 93 octane in my mercruiser 3.0l he said i was merely wasting money.
Common misconception. It's due to "Marketing".i thought this was interesting because i was always under the impression that higher grade octanes, would give you more power/performance.
A decade or two back, BP (which was AMOCO at the time) said flat out that their "Gold" gas (Premium) provided more power, better gas mileage, and a few other claims. They were ordered by the powers that be to prove any of it or to stop making the claims.
Guess which one happened? They stopped the claims.
Right below the gas cap on my boat, it simply states that the boat was tested and tuned for 88 octane gas. So I assume that I can use either or, and I simply prefer the 89 octane. Just seems to run just a little smoother with a better gas. I also use a fuel/carb cleaner every fifth fill up.
It isn't "better gas" -- it is higher octane. Higher octane does not add power. It decreases detonation/pre-ignition. Only if the ignition system has a knock sensor which detects detonation and can therefore control spark advance, would adding higher octane fuel be advantageous.
Well I guess that would also leave to question that if it does all of those, and it burns hotter allowing for less un-burnt carbon build ups. Then overall all I would say it is a better gas then 87, it just might not be of any better quality. Of course this all depends on where you buy your gas to begin with, and what company was in charge of refining the crude to gas.
