Trevthefox
- Joined
- Sep 25, 2018
- 101
Found a lifter failure on our 460 and it looks like we're going to swap cam shafts as a result. Need some advice on choosing the right camshaft. The book only gives the specs on lobe lift of this engine. (Intake .285 Exhaust .290 with max allowable lift loss .005) Most websites only give valve lift specs now which isn't a big issue since I know the rocker arm ratio. I was able to find a couple cams that are within the lobe lift specs, but not exact.
My only worry now is duration. The book doesn't give me the specs for intake and exhaust duration. Any clue on those specs?
Also, I do have a donor 460 (wasn't in the greatest shape). I could remove that cam and get it polished, but was thinking if I spend and extra $60 - $100 I would have a brand new cam. I greatly appreciate any advice you guys might have.
Thanks
Thanks
