I removed my 89 OMC Cobra to grease the u-joints. In the process I replaced the pick up screen, all the o-rings and seals I had access to. Also replaced the shift cable & both shift box cables. My question is how does the OD go back on?? I spent two frustrating hours with the OD balanced on a jack while trying to get the U-joints past the upper boot seal. Man what a pain! I have the seal pretty scarred up thinking I need to replace it before trying a repeat performance. The outter lip of the sea folded back inside and was cut up while trying to install the OD.<br /><br />Any tips or tricks getting this thing back on would be greatly appreciated! I tried using two big bar clamps but that didn't help much. I did read here that someone used a ratchet-strap to help force it in. I might give that a shot this week.<br /><br />Thanks all!<br />Geno
