'89 omc cobra water pump adapter removal
86 century
Ensign
I have a '89 omc cobra that is leaking lube around the shaft that drives the impeller.
Problem is i cant find a proceeder for removing the water pump adapter.
Any help would be appreciated.
a70eliminator
Re: '89 omc cobra water pump adapter removal
Remove the two screws that hold the adapter and carefully work around it using some some gentle pry action, there are o-rings behind it leaking.
sea wolf
Water pump shaft seal is probably shot. Also plan on replacing the 0-ring around the adaptor & gaskets. Use vise grips & try to pull it straight out. Be careful if u try to pry it out. The adaptor can crack & they ain't cheap!
86 century
Ensign
OK
I was hoping there was some other way but it looks like gentle force and a praying.
Thank you for the advice.
