It sounds like it's a shorted wire or a bad sensor. The test "chirp" is normal when the key is turned on but if your getting a sold beep right after start up it may be a bad temp sensor in one of the heads or a bad sensor in the oil tank. disconnect the tan wire to each of these one at a time while the buzzer is buzzing and see what happens.
