I have a power problem with my 85 hp Suzuki. At first it would not get put on plane. I have rebuilt carbs, fuel pump and new bulb and connector. The boat will get on plane after awhile and seems to run fine once there. But he has no power getting out of the hole or trying to put it back on the trailer. I was testing the throttle valve sensor (IC system) today. The sensor burned up with only about 9.5 volts applied to it. Connections were correct, black/red lead to the power source(variable power supply), black lead to ground and green/red to the volt meter. Don't want to burn up the new sensor when it comes in. Any ideas why it burned uo?
